Author Topic: "pure" sine wave inverters (sunforce pro series in particular)  (Read 1982 times)
Offline kyedo2002Topic starter
I wanted to know if since a/c inverters list a peak and a continous output if you could "hack" the inverter by specifically cooling components because I imagine the peak period is short because the inverter simply can't(doesn't for marketing reasons) have this extra feature.
Offline Paul Price
Re: "pure" sine wave inverters (sunforce pro series in particular)
« Reply #1 on: May 24, 2013, 11:31:15 pm »
Get a  fan, the only difference between a hot convertor that gives you the current your want and a cold one that does is cooling.
