Author Topic: potentiometer voltage limit  (Read 652 times)
Offline ascotTopic starter
« on: August 11, 2020, 02:55:04 pm »
is there a limit on how much voltage you can put through a pot if so how do i calculate it
Offline tooki
Re: potentiometer voltage limit
« Reply #1 on: August 11, 2020, 02:59:19 pm »
It’s not something you calculate. You look it up in the datasheet.
Offline TimFox
« Reply #2 on: August 11, 2020, 03:00:15 pm »
The maximum voltage across a potentiometer is normally limited by the power rating of the potentiometer, which should be quoted.  A 1.0k, 1/2W unit would be limited to 22 V, preferably derated to less than 15 V for a 2:1 power safety factor.
Where things get tricky is if you are using it as a variable resistor, where the power for a given voltage varies with the change in resistance.
By definition, a potentiometer is used as a voltage divider, but there may be current passing through the wiper.
The following users thanked this post: ascot
« Reply #3 on: August 11, 2020, 03:09:05 pm »
problem with data sheets is coming from amazon they tend to have very little info
Offline tooki
« Reply #4 on: August 11, 2020, 03:12:41 pm »
Well, it’s not wise to use no-name components for anything involving higher voltages.
If amazon has a part number, google it with “datasheet”.
But also consider moving away from Amazon for electronic components — they tend to not be especially good prices.
« Reply #5 on: August 11, 2020, 03:17:09 pm »
would tend to agree having seen one go up in smoke only advantage with amazon is i can pick delivery day
