Hi Folks,
I have a pulsed signal and I would like to measure the BW of the high power frequencies in it as shown in figure below. The shortest pulse shall be in 100 us.
I will build a circuit and will use a microcontroller for that.
The signal looks like a chirp signal but somehow in digital fashion with DC offset. I can see the frequency of the signal increase with time so I called it digital chirp signal. I don't know if it has a scientific name or not !
I thought of the following techniques:
- collect samples via ADC and use FFT to figure out the high power frequencies and measure the BW.
- use pulse discriminator to figure out the positive edges and measure the time between them
- use zero crossing circuit and measure the time as point above
- use PLL and measure the voltage before the VCO to figure out the frequency ranges
is there a simpler or more recommended solution for such problem statement ?
