You must consider that there are different ways to practice safety and in fact, these different ways do work well and are used by not just me but thousands of electronic service people in this big world. And the same non-grounding, GFI wiring standards are the standard for electrical connection and the safety of household wiring in some countries, other than the one you are living in.
Indeed,but you are falling into the same trap----many thousands of people throughout the world have used "PE" wiring & the associated equipment without any problems.
In fact,back in the day,many homes had domestic radios with "figure 8" power cables sitting in the kitchen in close proximity to earthed refrigerators,kitchen sinks,etc.
In Australia,these were all quite safe,as they used transformer type power supplies,so the Mains were pretty much restricted to the on/off switch & the transformer primary.
If they failed,they may well have been tested using bench test equipment such as VTVMs & Signal Generators,all of which were earthed.
The incidence of fatal electric shock to Radio servicemen was vanishingly small.
Of course,these days,Test equipment is still earthed,but much domestic stuff is not.
What we DO have is RCDs as a mandatory fitment to any new wiring,so I reiterate,GFI/RCDs & PE wiring
are not mutually exclusive.
Most of the panic about Electrical safety is overdone,at least as far as Engineers & Techs are concerned.
Over some 40 years in Radio & TV Broadcasting,I have known about 4 people who died accidentally__
One crashed a "Pitts Special" stunt plane, two others died in falls,& one was washed off the rocks while fishing.
Electrocution?---not one!
