Author Topic: Is it totally safe to short an open drain output of an IC to ground?  (Read 301 times)
Offline mbmsvTopic starter
Let's say I have a design that controls some active low output signal using an open drain output and I want to provide an option for a user to force this signal to low. Can I simply add a jumper between my output and ground? The pull-up resistor is a part of my circuit, so I know that the current through the jumper will be small. Thanks.
Online Benta
Re: Is it totally safe to short an open drain output of an IC to ground?
« Reply #1 on: January 05, 2024, 10:55:24 pm »
Yes. That's what open-drain outputs are for.
The following users thanked this post: mbmsv
