Circuit in FalstadLikely going to get this circuit made by a PCB manufactuer to be used for various things. It's just a basic constant-current control, from 0-2A. My only problem is that I can't figure out how to
LOGARITHMICALLY control the potentiometer, to have fine-control at 0-100mA, and less control at 100mA-2A. I know that I could simply use a logarithmic pot, but is there any other way to have the circuit act in a logarithmic manner?
Design-rationale (before people ask):
- The first op-amp is to simply decrease the input resistant into the second op-amp.
- The 70k resistor to ground at the input of the second op-amp exists so that
if the pot breaks, only ~5mA will be allowed to flow through the FET.
- I know that I'll need a compensation capacitor at the FET to reduce ringing
- I'm using a 0.1ohm resistor to reduce voltage drop at the 2A load
- The op-amp I'll be using to measure the ~0.5mv voltages at the 0.1ohm current sense resistor is the Microchip MCP6V97 (+/- 25μV at 25C).
