Author Topic: what are these tabs  (Read 931 times)
Offline LaserTazerPhaserTopic starter
what are these tabs
« on: May 07, 2019, 07:05:06 am »
Going to obtain a DO-5 diode https://www.digikey.com/product-detail/en/VS-70HFR120/70HFR120-ND/352028 and it comes with everything but the washer with solder tab hole found in listing https://www.ebay.com/itm/123138968087 but I don't need the other things in that kit. Trying to find that solder washer on Digikey but not sure if they even sell them individually or if they even carry them.
Online MarkF
Re: what are these tabs
« Reply #1 on: May 07, 2019, 08:10:13 am »
The following users thanked this post: LaserTazerPhaser
« Reply #2 on: May 07, 2019, 10:13:25 am »
I have many of those but Id like something with more surface area as those in the ebay listing.
« Last Edit: May 07, 2019, 10:24:36 am by LaserTazerPhaser »
Offline wraper
  • Country: lv
Offline wraper
  • Country: lv
« Reply #5 on: May 07, 2019, 10:32:22 am »
« Reply #6 on: May 07, 2019, 10:54:42 am »
This one has 6.35 mm hole. https://www.digikey.com/product-detail/en/keystone-electronics/4712/36-4712-ND/316279
The one without any data input into their fields, will obtain these. I typically use filters to find items.
« Last Edit: May 07, 2019, 10:59:28 am by LaserTazerPhaser »
