Author Topic: Home sound system  (Read 1105 times)
Offline SavethedayTopic starter
  • hobby technician
Home sound system
« on: August 02, 2022, 06:33:58 pm »
Hi Everyone
I just move to house with on the ceiling 5 speakers with different cable connections .Actially There is also separate 2 cables that connected to next room Right and Left speakers. Is it possible to make that system home theater sound system? What kind of amplifier do I need?What would you recommand?
Thanks
  • hobby technician
Re: Home sound system
« Reply #1 on: August 02, 2022, 06:35:22 pm »
AND
« Last Edit: August 02, 2022, 06:39:05 pm by Savetheday »
Offline james_s
« Reply #2 on: August 02, 2022, 07:02:07 pm »
That's exactly what those are for. Any standard A/V receiver should do the job, they're ordinary speakers, just set up your receiver the same way you would with floor speakers but hook it up to those wires instead.
The following users thanked this post: Savetheday
Offline rooppoorali
  • Country: bd
« Reply #3 on: August 03, 2022, 08:31:22 am »
  • hobby technician
« Last Edit: August 03, 2022, 01:03:29 pm by Savetheday »
Offline KellyGreené
  • Country: ng
« Reply #5 on: August 03, 2022, 04:20:05 pm »
Yes, you can turn it to a home theater system. It's possible the previous residents did that. For the kind of amplifier you need, you can just do a research online to find an amplifier that'll meet all your needs as everyone's preference differs.
Offline james_s
« Reply #6 on: August 03, 2022, 06:20:02 pm »
Don't you have a home theater receiver already? Or do people not have those anymore? They were ubiquitous for many years, every thrift store usually has a few of them.
Offline TomWinTejas
« Reply #7 on: August 03, 2022, 06:20:41 pm »
And the coax with the F->RCA adapter is for your subwoofer.
Offline macboy
« Reply #8 on: August 03, 2022, 06:38:58 pm »
Honestly I would suggest to get a 9 or 11 channel Atmos receiver, and use 4 of the ceiling speakers for front and rear height channels. Then add ether 5 or 7 speakers for front and surround channels. I have Atmos in my basement theatre with ceiling speakers and it is amazingly enveloping. I also have Atmos in my living room with reflecting(up-firing) speakers and that works ok as well. Another option is to use the back pair as surround speakers, and the front pair as front height (without using any rear height channel). You'll need to add a pair of speakers and centre speaker for the front channels. You don't really want dialog coming from the ceiling. High mounted surround channels can work well though.
