... the one shot trigger of a DSO makes all the difference in the world.
Psssttt .. this is the biggest secret recipe that most noobs never get it for 1st time, especially when in confusing moment in choosing analog vs digital scope, and when it times and this will bite really hard, its really-really painful once the noob realized it.
To OP, if you thinking real man uses analog scope, let me share you story about analog scope, I own Tektronix 2465B 400Mhz beast, lots of experienced people recognized it probably one of the best analog portable scope ever made on earth.
Tell you a dark secret about it, this particular scope, even its never used from factory, still sealed in original plastic wrapping, resides in the original factory box, and never exposed to humidity nor extreme bad temperature, still it will rot by it self. And when you hook up to AC mains to power it up, there is a big chance the power supply part will explode and smoke your room with nasty smell.
Btw, if you're so confident, just get one, and btw, in order to fix a scope, 99% you need "another" working scope.
