Hi guys,
I have a lab assignment on mosfets for my class and one part is to construct a flow chart describing how to identify the characteristics of a 4 terminal unknown mosfet using just a ohmmeter. They want to identify the gate and body terminals, classify as n-channel or p-channel, and determine if it is enhancement mode or depletion mode. Sounds pretty easy but I want to run what I have by you guys and see if I missed something. Also, I made the assumption that there are no protection devices on the part (drain/source diode, gate protection diodes, etc.) to make things easier (not sure if I will get dinged for that, but it seemed reasonable).
Ok, here goes:
Step 1: Identify gate terminal
Does lead x conduct in either direction to any of the other leads?
Yes: Change to lead x = x + 1 and repeat Step 1
No: Lead x is the gate terminal, proceed to Step 2
Step 2: Identify body terminal
Does lead y conduct in foward direction to both of the remaining leads?
Yes: lead y is the body terminal, device is N-channel, proceed to Step 3
No: does lead y conduct in reverse direction to both of the remaining leads?
Yes: lead y is the body terminal, device is P-channel, proceed to Step 3
No: change to lead y = y + 1 and repeat Step 2
Step 3: Determine mode
Tie gate and body terminal together (to short the MOS capacitor)
Do the remaining two leads conduct in both directions?
Yes: Device is depletion mode
No: Device is enhancement mode
I think my logic is flawed on the determination of depletion vs enhancement mode, but I don't have a 4 terminal mosfet of either type to test (crappy lab to not give us these). If you connect the gate to the body, then it would seem there would be 0V across the silicon oxide layer capacitor and thus if the device were enhancement mode there would be no conduction channel. If the device were depletion mode, then the channel would exist since there is no voltage to "quench" it. I am wondering about the drain/body and source/body diode junctions though, and how those might affect the ohmmeter measurements.
thanks for reading all of this and any insight you guys might have!
