Hi all,
I've just got a new bench power supply - and I've been playing around with it with my scope - looking at the noise on/off etc.
I have a Rigol DS2072 with the 300Mhz "option" - but still on v2 - haven't touched v3.
My question is - I have my bench supply set to 5v. (the setting doesn't matter but let's go with 5v). If I meter across the outputs with my multimeter I see bang on 5v. If I connect my scope though - I only see 1v. If I chance the setting on the bench supply to say 10v - the multimeter sees it just fine - but the scope sees 2v.
What am I doing wrong on the scope to get the scale/output on the scope wrong like this? (I've tried a restore to defaults with no luck).
Cheers.
Scotty
