I would like to install lots of temperature and relative humidity sensors in a building. With central monitoring and logging. About 40 sensors in total. This number will probably grow over time. Later on I would also integrate some other sensors as well (pressure; light; CO2; presence;...)
2 or more sensors might be installed in the same location.
What is the best system/bus for this application?
I was thinking about one-wire, cheap and easy for temp logging (DS18B20), but I could not find something for relative humidity, probably didn't search far enough yet.
Central unit will be a raspberry Pi or similar. With main function logging and communication/reporting.
Thanks in advance for the help.
