Author Topic: Multimeter probe slipage  (Read 5956 times)
Offline obiwanjacobiTopic starter
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« on: February 08, 2015, 05:23:28 pm »
Just made nasty mistake where I slipped of a pad with my multimeter probe and caused a short - blowing up a diode in the power supply section (and maybe more)...
I know probes should be sharp so they dig in a bit and prevent this sort of thing - I will look into that. Meantime I was wondering if there are techniques or (tips and) tricks that could help me with this.
Thanx!
Marc
Wrong code should not compile!
Offline Lightages
  • Canadian po
Re: Multimeter probe slipage
« Reply #1 on: February 08, 2015, 05:33:44 pm »
For close spaces and close pins you should use different probes. There are many available with only the end points exposed. Other than that, use stand or helping hand to position the probe or use extreme care. You can also tape off the areas you don't wan to accidentally touch.
Offline mij59
Offline rqsall
« Reply #3 on: February 08, 2015, 06:37:58 pm »
I have two pairs of those. I've hurt myself on them. Dangerously sharp, when you grab them, make sure you approach them on the safe side...
Offline Nerull
« Reply #4 on: February 08, 2015, 09:35:56 pm »
I have a set of Probemaster spring loaded micro probes which do a much better job of staying in place on fine pads than my standard fluke leads. Pomona makes a similar product, but I haven't used them.
Offline electr_peter
  • Country: lt
« Reply #5 on: February 08, 2015, 11:31:23 pm »
Standard multimeter leads (designed for multi-purpose use) have very wide finger guards. These guards effectively prevent you from probing 2 close points on the circuit.
Get some smaller leads with smaller guards or no guards and very sharp (preferably spring loaded) tips for PCB probing.
Offline nanofrog
« Reply #6 on: February 09, 2015, 01:04:13 am »
You might want to look into spring loaded/pogo probes as well (example).
Offline rx8pilot
« Reply #7 on: February 09, 2015, 01:26:46 am »
My super high-tech solution to probe holding on circuits that will die if I slip.
Offline retiredcaps
« Reply #8 on: February 09, 2015, 04:51:51 am »
If your hand slipped because you moved your head to look at the lcd display, there are some multimeters that will freeze a stable reading and then beep.  Fluke calls this touch or autohold.  Others have similar capabilities.
    • Marctronix Blog
« Reply #9 on: February 09, 2015, 06:26:18 am »
Thanx everyone.
I took the tips to a piece of 400 grit sandpaper and they are a lot better (sharper) now.
I will also isolate part of the exposed shaft - that is an excellent tip.
I was trying to measure the input voltage on a 7805 while the circuit was mounted and hooked up (its a guitar amp so needed speaker load). The whole contraption was in a bit awkward position - beyond that I am not sure what caused me to slip...
Offline codeboy2k
« Reply #10 on: February 09, 2015, 07:38:17 am »
Turning to look at the LCD is usually when I slip a probe.  I started using the auto-hold feature more and more as pin pitches got smaller and smaller.
I saw a cool probe holder that a guy was using at a show once, it was a table top unit, an adjustable pc board hold-down and two or more X-Y pen plotter like things that could hold multiple probes vertically on the board underneath.  The x-y probe holders were moved manually and placed where needed.
EDIT: +1 for Probe Master probes.  I have Probe Master probes.  These are the sharpest tips I have ever seen on a probe.
« Last Edit: February 09, 2015, 07:40:21 am by codeboy2k »
Offline nanofrog
« Reply #11 on: February 09, 2015, 10:54:03 am »
Same here. The SMD/pogo versions are so sharp in fact, you can draw blood without even feeling it pierce your skin (single point tips).  :o   :palm:
Offline VK5RC
« Reply #12 on: February 09, 2015, 11:13:17 am »
I swear by these little fellas, if need be you can bend the shaft by 30degrees or so, they can fit in-between cards . great for locking onto DIP pins esp if the IC is a long way in and the circuit is hot. Repairing a HP 6644A recently has the   " joys" of the heatsink is at 110V DC above ground.
http://www.ebay.com.au/itm/Set-of-8-Tektronix-Tek-SMG-KlipChip-Adapter-Surface-Mount-IC-Grabber-Clips-/291358216975?pt=LH_DefaultDomain_0&hash=item43d64d930f
Offline nanofrog
« Reply #13 on: February 09, 2015, 11:37:40 am »
Found this dial indicator holder that might be of interest for a longer reach.
