Yes, but there are no base resistors on those transistors.
And there are extra resistors from the emitters to ground. I think these might limit the base current, since it's actually IBE, so the base current flows out of the emitter, but that will also affect the collector current going to the LED. I've never seen this approach before though. Maybe because it's wasteful.
