Author Topic: MSP55LV100S Read / Program  (Read 3284 times)
Offline GadgetUKTopic starter
« on: November 04, 2013, 11:33:19 pm »
Sorry if this is in the wrong section...  I am after a bit of advice on how to reprogram a MSP55LV100S chip.  I believe these are NVPROMs, which I think I should be able to reprogram with the correct hardware.  I cannot find a data sheet for this device so I am a bit clueless where to begin.
I have one of these on a PCB, and I am sure its corrupted - generating noisy sound on Neo Geo MVS.  I can remove the chip but not sure how to go about reprogramming it.  Does anyone know of a cost effective way / programmer to do this?
I've got a couple of EPROM programmers but they are for 40 pin or less chips, and I am guessing this particular chip could have some serial interface or something for programming?  I've also got a USB 3 in 1 JTAG programmer but not sure if that could be used or not without understanding how this chip works, or more specifically the pin out etc.
Offline amyk
Re: MSP55LV100S Read / Program
« Reply #1 on: November 05, 2013, 08:36:54 am »
Game system? Most likely mask ROM, followed by PROM. Neither are reprogrammable.
« Reply #2 on: November 05, 2013, 10:34:14 am »
Sorry but your assumption is incorrect.  These chips have been reprogrammed already - I can tell they've been reclaimed from other systems.  Just need to work out how I can reprogram them.
