Now the circuit IRL, works ok sometimes, but other times, it has oscillations, and the open-loop gain of the DUT op-amp, makes it's output jump a lot. The tests for input bias currents +IB, -IB can work ok sometimes, I've gotten legit figures that match datasheets.
I'm using some brand-name sample book SMD caps, for the 10uF cap. Looking at the eqn's I got, and the sim, I see the circuit acts like a LC-low pass filter. And I was having some 120mVpp 12Hz osc. when in Vos mode. So I added a 4.7uF cap in parallel with the 99.9k Rf. And it seemed to be nice and stable, for about 1minute. And then the output goes walk about, not any nice 12Hz sine-wave tho.
I used 2x100nF caps on both DUT and AUX op-amps, and I have 10uF on both rails. And both rails are behind a power switch. And I have very small size switches (expect voltage levels) all in place. I pretty carefully choose all the resistors, but most of them are just cheapo 5%, since I have a huge bag of 100k's and 100's, and could use a single resistor.
The layout is fairly neat and besides stray capacitance, I'm guessing loops don't matter at all for the 12Hz from the 110k and 10uF cap.
But the Rf resistor is over an inch, or 26mm, away from the op-amp socket. I've scrapped and cleaned all the flux off the proto-board. There's a chance there's RA flux under the 4 SMD caps I used, and I know this flux has issues with leaving a conductive sludge.
But I find this typical of op-amps, where I'm not sure if it's my probes sometimes, but the DMM see's it too. But the output just goes off all over the place sometimes. And they don't warn about this in the pdf, or use as detailed of eqn's as I did. But IDK how else to fix this circuit.
But I did leave the other 1/2 of the PCB empty, to add some Texas Inst. versions of these same tests. It will be nice to have another version to compare with, right on the same PCB.
