Author Topic: Need help identifying components in SeekThermal  (Read 2032 times)
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« on: June 14, 2016, 08:10:36 pm »
I plan to draw a complete schematic of SeekThermal but I can't identify this two components:
Markings: CI
Dimension: 1mm x 1mm
Element:
Pcb pads:
Markings: KG 05 (or OS) 4M
Dimension: 2.54mm x 1.24mm
Element:
Pcb pads:
And location of both components:
Please help.  :)
« Last Edit: June 14, 2016, 08:15:59 pm by frenky »
  • Country: si
    • Frenki.net
Re: Need help identifying components in SeekThermal
« Reply #1 on: June 15, 2016, 06:33:29 am »
I identified the "CI" element by measuring voltage. 5V goes in and 2.8V goes out so it's voltage regulator...
This one is still a mistery:
Element:
Pcb pads:
  • Country: si
    • Frenki.net
« Reply #2 on: June 15, 2016, 07:04:09 am »
Ok mistery solved... All 4 pins on the left go to USB connector. :palm:
