Author Topic: Which Book on Transformers?  (Read 3119 times)
Offline StubbornGreekTopic starter
« on: August 14, 2013, 09:17:18 pm »
My knowledge of transformers is not what it should be (I understand the basics but that's about all) so I'd like to build a better understanding.
Which resources should I consider (I'm looking for working knowledge, not just theory)? Are there any great books on the subject or could I find all the information I need using our friend google?
Thanks for your guidance, in advance.
"The reward of a thing well done is to have it done"
-Ralph Waldo Emerson
Offline KD0CAC John
Re: Which Book on Transformers?
« Reply #1 on: August 14, 2013, 09:27:01 pm »
I want to fallow your thread .
I am wanting build a large power supply to test RF amp tubes and sometimes see surplus transformers and want to have a enough knowledge to tell if some thing I see is able to work for what ever project .
I will have to give you what I have found so far ,
http://www.tone-lizard.com/Transformer_ID.htm
http://www.radioremembered.org/xfmr.htm
http://www.heyboertransformers.com/
http://ludens.cl/Electron/Magnet.html
That should get us starter .
« Reply #2 on: August 14, 2013, 09:38:37 pm »
Here's a good link (I believe) on winding:
http://ludens.cl/Electron/trafos/trafos.html
Offline JackOfVA
« Reply #3 on: August 15, 2013, 01:07:18 am »
You might find Ruben Lee's 1955 book "Electronic  Transformers and Circuits" worth reading. It's a free download at
 http://www.tubebooks.org/Books/Lee_1955_Electronic_Transformers_and_Circuits.pdf
It covers  both power transformers and signal transformers.
The following users thanked this post: kg4arn
Offline Kremmen
« Reply #4 on: August 15, 2013, 09:52:40 am »
Book? This: http://www.amazon.com/Inductors-Transformers-Electronics-Vencislav-Valchev/dp/1574446797/ref=sr_1_1?ie=UTF8&qid=1376560005&sr=8-1&keywords=bossche%2C+valchev
It is expensive as hell but the info is 2nd to none (cheaper copies may be found in the net). Unfortunately the comment on Amazon website concerning the greek symbols occasionally mismatching is true. Somewhat annoying but not fatal. Other than that, IMO among the best. Check the table of contents, visible on Amazon site, if it is a match for your requirements.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline liquibyte
« Reply #5 on: August 15, 2013, 10:25:43 am »
Not sure if it should be in the open like this but a google search gives this result first:  Inductors And Transformers For Power Electronics
Oh, and I've found the math behind most of this unnecessary due to the ludens.cl site.  That guy makes winding your own transformers look easy and his math seems to work but ymmv.
« Last Edit: August 15, 2013, 10:30:49 am by liquibyte »
« Reply #6 on: August 15, 2013, 05:27:37 pm »
Fantastic resources. Thank you VERY much!
Unless there are any others that I should consider, I think I have enough reading material for a while.
Offline planet12
« Reply #7 on: August 16, 2013, 05:29:17 am »
Adding to those already given (with definite props to ludens.cl - his explanations and consistent use of the sane SI units really help, and I find myself continuing to refer to his materials):
TI's MAG100A series: http://focus-webapps.ti.com/docs/training/catalog/events/event.jhtml?sku=SEM401014&section=Agenda
"Transformer and Inductor Design Handbook" - Colonel Wm. T. McLyman - http://www.amazon.com/Transformer-Inductor-Handbook-Electrical-Engineering/dp/1439836876
« Reply #8 on: August 16, 2013, 05:41:45 am »
^ Thanks again.
