Hi everyone,
I'm currently attempting to design a circuit to power the
FAN7631 on start-up. I'm currently planning on using the method outlined in the third post in this
thread. (I didn't want to post in that thread because it's in General Chat.)
The general idea seems pretty straight forward, the capacitor is charged slowly through Rstartup. Once the voltage over the capacitor (Vcc) reaches the minimum threshold voltage for switching the FAN7631 will start conducting. Then the auxiliary winding of the transformer will start supplying current before the Vcc drops below the minimum voltage required for switching.
Now, it seems the minimum starting voltage (HVcc) for switching the high-side MOSFET is 9.2V, while that of the low-side (LVcc) is 12.5V. Now assuming I'm looking at the correct datasheet values it looks like the high-side MOSFET will start switching first and Vcc will drop before the low-side starts switching.
Assuming I am using the correct values would a solution be to add a resistor to the HVcc line so both HVcc and LVcc start switching at 12.5V? I have noticed in the datasheet they add a series resistor and diode to the HVcc line, is this why? Let me know if my questions are unclear or if you require more information.
