I am trying to trouble shoot a board and was checking the diodes and came to this one that the reading is not as I think it should be.
It is an SR206 A11 (black w/silver band)
In google it pulls up a data sheet for a schottky.....
I get a .198 reading using the Fluke 87V....
I am getting a .4 range on all the other diodes on the board but I was not sure on a Schottky if it is expected to show similar good range as the other types.
I pulled it out of circuit to test because it is beside a coil and reads both ways when in circuit.
if I reverse polarity it holds the OL reading as it should...
Any help appreciated... I looked at the datasheet but am still too green to decipher more than the obvious
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
(I don't have a replacement but I don't want to put a bad part back in either)
Thanks a mill....
