Please excuse the pride post, but I've been trying to practice my perfboard skills.
It's just an ATMega328p minimal board.
... and it's ugly bits ...
Features:
* Red 5mA power LED
* Blue 5mA test LED on PIN (IDE) D9
* 5 pin serial programming header
* Reset switch w/ 10K pull up
* 16Mhz xtal with 22pF load caps
* 100nF decoupling cap
The epiphany was using component leads, either from the ones you are using in the circuit or some cheap blue chinese resistors cut up to make the tracks on the underside. At the very last minute I cooked the power LED somehow. Ended up having to drill the holes back out to remove it, but I managed to get a new one in and nobody would even notice. It's always the last bit that goes tits up. Also... why is it that the best solder joint you make is the one you weren't meant to?
There is another phase to this as I want to add the ISP header on the other side of the chip. I'm calling the AVR designers some interesting names for crossing power pins and the ARef pin polarity as I "could" have just linked across under the chip, but they are crossed, so I will need at least one insulated link on the underside.
It's a practice precursor to my next perfboard project which will be a binary clock. It will be a bit of a step up as it entails:
* an ATMega328p
* 2x 74HC595 shift registers (mins and secs)
* RTC chip
* Battery backup
* 16 LEDs
* 16 Resistors
