Author Topic: Identify motor  (Read 1598 times)
Offline acinhoTopic starter
  • Country: si
Identify motor
« on: July 20, 2017, 07:47:37 pm »
So I pulled this non-functioning (no stator winding and no nameplate) motor from a table saw and I need help identifying it.
http://imgur.com/a/A8JWE
My guess is that it's a single phase induction (asynchronous) motor.
There is also a capacitor present and the rotor looks like a squirrel cage type but I'm not sure.
I'm also curious what that spring is for. Could it be some sort of a centrifugal switch?
Any help would be appreciated!
Offline Zero999
  • 0999
Re: Identify motor
« Reply #1 on: July 20, 2017, 08:42:05 pm »
That's not a motor. It's just the rotor. Does the shaft spin on the bearings? If the bearings haven't seized up, then the fault lies with the stator, start capacitor and/or any control gear such as contactors and switches.
  • Country: si
Re: Identify motor
« Reply #2 on: July 21, 2017, 09:02:19 am »
I realize this is just the rotor. The bearings are OK.
Problem definitely lies with the stator because there is no stator winding present. Previous owner took it out, I guess he was trying to rewind it.
Offline cs.dk
Re: Identify motor
« Reply #3 on: July 21, 2017, 09:07:01 am »
Throw it out.. Really, AC motors are so dirt cheap, it's not worth 10 minutes.
