Author Topic: Logisim  (Read 2653 times)
Offline rudolf97Topic starter
Logisim
« on: August 09, 2014, 06:02:25 pm »
Hi!
I am a noob in electronics and I want to get into it. I found some nice german tutorials (of course my language) about making a 4-Bit cpu with Logisim. So now I want to know if its a good idea to learn in Logisim and if it is good to engineer things in there?
The software can be found here: http://www.cburch.com/logisim/
Regards
Rudolf
Offline zerorisers
  • young noobie, my apologies for low knowledge base.
Re: Logisim
« Reply #1 on: August 09, 2014, 06:15:19 pm »
Hi!
From the link the first pages image looks like it can be very helpful. I might actually install it myself. I believe it would be worth learning logisim personally. Nice way to simulate these logistic circuits.
Best of luck,
zerorisers
Offline bwat
    • My website
Re: Logisim
« Reply #2 on: August 09, 2014, 06:23:37 pm »
Tutorials are OK if it's a niche area which doesn't have any good textbooks covering it and the tutor is an expert. However, there are a handful of good digital design books which will teach you how to design and build your own CPU. I would get my hands on a good book and work through it.
As for multisim, well if it works then why not learn it and use it for simulation. If, on the other hand you want to realise your CPU in FPGA or silicon, then you might want to learn something like Verilog or VHDL (*). If you want to see CPU designs in Verilog then have a look at some of the links here. All of the code was written whilst going through the book
Mano, M. Morris, and Kime, Charles R. Logic and Computer Design Fundamentals. 2nd Edition. Prentice Hall, 2000.
*) Note that you can still simulate designs written with Verilog or VHDL.
« Last Edit: August 09, 2014, 06:31:13 pm by bwat »
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
Offline NRoach44
Re: Logisim
« Reply #3 on: August 10, 2014, 04:56:03 pm »
The Digital design unit I did last semester in Uni was building parts of a processor in logisim. We followed the book "Digital design and Architecture" (David and Sarah Harris). While we didn't actually build a CPU in it, it required understanding the 8-bit MIPS CPU the lecturer built in it.
I'd say as long as you are following a book or working towards some goal it should be fairly good as a learning experience.
« Last Edit: August 10, 2014, 04:58:02 pm by NRoach44 »
