Sorry I didn't set location. The country is Russia, and we may have a slightly different market here, because there are cheaper local manufacturers that only trade locally and there's plenty of Chinese import of course. So knowing tech specs would help more than brands. As for budget, I'd like to keep it under $150 overall, but again it wouldn't tell you much, there are $2 soldering irons available here, go figure.
You'd think the tech specs would be enough to go on, but that may not give you the full picture. For example, you can have say a 55W JBC station outperform a 100W temp controlled station primarily due to the heating technology used (cartridge tip vs. traditional separate tip & heating element).
There's also other considerations, such as quality, cost, and availability of spares and consumables such as tips (don't underestimate the importance of this).
As per what will fit your budget, that's going to be a bit tough in Europe, but not impossible. Batterfly sells the
Hakko FX-888D for less than that (98EUR before VAT & delivery), so you'd have money left over to put towards tips if you haven't put aside a separate budget for this.
Recommended Tips to Start:
You can do an amazing amount of things with just these few tips actually. A bent chisel or two is nice for example, but not absolutely critical to have (more comfortable for some tasks, such as soldering connectors). And there's also personal preference. Some might prefer a hoof for a task that a chisel would also work.
To get an idea of what I mean, take a look at
Hakko's Tip Selection Page (by operation, how to select tip size for the job, ... options).
If you have to go with a Chinese brand, you should take a look at
Quick brand (lots of stations on this page if you move the cursor over the different tabs above the photo). Others have said
Xytronics (very crappy website) and
Solomon are decent (both are in Taiwan). Not sure if pricing on these will be much, if any cheaper than the FX-888D though.
Quality supplies are also on the pricey side, but well worth it (they also tend to last a long time).
Thank you for the tips, what I wanted to know is whether there are some things without which I simply can't solder SMDs, apart from solder wire and flux of course.
I understand there aren't, and having a temperature controlled soldering iron with a good selection of tips covers most use cases with some patience and quality supplies, correct?
Most cases, Yes.
There are exceptions, namely BGA packages.
