Hello guys,
I know this subject has come silent, so let me know if I should post my own subject. But thing is, I think there is only this subject about this NEC GPSDO here...
I recently bought a board from eBay, it came without the OCXO. I powered the board, it works (there is a PPS signal at the LEA-5T). So I'm now looking for an oscillator. The Epson Toycon looks to have a control voltage ranging between 0-10v, centered at 5v. I was looking at some MV-180, but they are expecting a control voltage between 0-5v. Would the board be able to "learn" the control voltage, would it be safe for the MV-180? Or is there another reference I should be looking at?
Remi.
EDIT 2023.07.14: The answer is yes. I bought a FEI FE-180 OCXO on eBay, the control voltage starts a bit high but stabilizes around 2.8 volts. Lady Heather reports everything good after a while.
