Author Topic: Electronic load - heatsinking / managing thermals  (Read 3947 times)
Offline ifonlyeverythingTopic starter
Re: Electronic load - heatsinking / managing thermals
« Reply #25 on: November 04, 2022, 11:55:01 am »
I found a partnumber for a good powerful heatsink, which works fine with a powerful noisy 70 mm fan. Here it is: IBM HEATSINK (40K7438) IBM X3400 / X3500 / X3650 (FRU 40K7438).
I have two of them. Tested one - it works fine with 200 Watts and 4500 rev/min 70mm powerful fan (and TO-247 FETs). A man who sold me them, said it may dissipate up to 600 W with a TO-264 FETs (?).
Those look pretty nice. How did you mount your FETs? Clamping, or drill & tap a hole in the heatsink base?
Offline Vovk_Z
  • Country: ua
« Reply #26 on: November 04, 2022, 07:53:39 pm »
drill & tap. It is made of something like pure copper (or copper-like alloy). It is pretty soft and drills very easily.
Offline MathWizard
« Reply #27 on: June 04, 2023, 04:37:39 am »
I've been wanting to make a DCEL to test some computer PSU's. I have a couple of real schematics that are similar to a lot of the low power ones you'll see. And I would probably combine that with something like Scullom Hobby Electronics DCEL, that and the 2 sch's are both digital.
Last year I tried some big iron sheets as heatsinks, and they can't even dissipate the heat fast enough for 1 fet at 20W. Maybe I was doing something bad to those modfets, or they were knockoff's. But I haven't tried anything since.
Now I have some nice op-amps, but for the cost of all the other parts, like a giant heatsink, I'm back to looking at brand-name ones.
I have a +10yo 1,200W PSU. I should just give up on testing that, I'd need a multi-rail tester built for 2,000W.
But then there's those low voltage, high power heating elements, like 12V 400W, and cheap. IDK if they are really suitable, since I don't see anyone else using heater elements. But for a resistive load, with pass mosfets trying to control it, is that a good or bad idea ? Like if I wanted to test a 750W PSU, may I'd only use 600W of heaters, and the rest could goto just power mosfets on a heatsink.
« Last Edit: June 04, 2023, 04:39:52 am by MathWizard »
Offline barshatriplee
  • Country: bd
« Reply #28 on: June 04, 2023, 07:38:17 am »
Using server CPU heatsinks can be a good option for cooling the MOSFETs in your electronic load. The Delta Electronics heatsink you mentioned (DHS-B9292-04A) with dimensions of 80x80mm and a thermal resistance of ~0.24°C/W can provide adequate cooling. You can fit two MOSFETs per heatsink, as you suggested. Additionally, using powerful fans and clamping everything together with bolts will help enhance the cooling performance.
Offline Jwillis
« Reply #29 on: June 04, 2023, 01:05:12 pm »
I run 8 FDL100N50F in the ELoad I built. It can sustain around 900W before the thermal shut down kicks in at around 100C. Eventually I would like to improve the cooling but it supports my needs for now.
Offline Jwillis
« Reply #30 on: June 04, 2023, 01:28:12 pm »
I would be wary of buying them on aliexpress. It is quite possible you won't get a genuine device.
I bought several from Digikey , Ebay and Aliexpress and they all work the same. Didn't see any difference between them. Aside from price.
Mind you I got them before the Covid thing so there was lots of them around then.
Offline MathWizard
« Reply #31 on: June 07, 2023, 07:16:32 am »
That heatsink is not very big, but that can almost handle 900W ? Where do people get large heatsinks from anyways, what did it cost? I had a quick look around and I was seeing prices like $350 for anything big. Insane price markup I'm sure.
I know I'd need the fans to have the right spec's too.
Offline Jwillis
« Reply #32 on: June 07, 2023, 10:53:34 pm »
With forced air it will sustain 900W for the 5 minute without further temperature increase on the  test i did. I won't kid you , It gets hot . But most of the of the time I use it at around 400W to 600W.
I lucked out on these heat sinks. Found them for $40 a piece . I check junk stores, pawn shops and scrap yards. Sometimes I get lucky. Even metal shops have scraps they will sell you for peanuts. After all what is a heat sink but a chunk of metal.
I do have an advantage of having lots of petroleum companies around that have scrap yards. Sometimes they will just let you take it. Saves them from hauling it away.
