The amplifier design allowed the use of resistors that could be up to 5% off the specified value. For example, if a 1k resistor was specified, the one used could have an actual value of between 950 and 1050 ohms and the circuit will work as designed. So getting a resistor that is closer to the nominated value is going to be completely fine.
As for getting them off eBay, you need to be careful. As mentioned above, you can come across rejects - which may or may not be a problem. For example, a couple of years ago, I got a really cheap 'grab bag' of 1% resistors - but when I checked their values, they were a bit off.... They were more of +0/-2% than +1/-1%. Fortunately, this wasn't really a significant concern for my needs.
The point is that you can't really be sure until you get the components and check them out.
