Thank God this was for begineers, i didn´t get most of the coments
Quote from: guillermo112 on May 16, 2011, 02:28:17 pmThank God this was for begineers, i didn´t get most of the comentswell. 1st thing 1st. you have to know what "frequency" is, and then you have to know what happen if two or more different frequency and amplitud mix together. at the same time you need to know what "capacitance" and "inductance" means. and if you go advanced, then you can look into what "reflection" is. as mr albert said... use your imagination. i'm also still struggling
