Author Topic: RF switch  (Read 508 times)
Andree Henkel and 2 Guests are viewing this topic.
Offline abhijitrkjrTopic starter
RF switch
« on: September 06, 2024, 10:22:24 pm »
Hi. I want to make an rf switch. I have two rf signal inputs and one output. I want to channel one of the inputs to the output using a TTL. The frequency range of my rf signal is 2kHz-1MHz and amplitude is 10V peak to peak. Any ideas how can I achieve it?
Online themadhippy
Re: RF switch
« Reply #1 on: September 06, 2024, 10:34:28 pm »
simplest way would be a relay
Offline G0HZU
Re: RF switch
« Reply #2 on: September 06, 2024, 11:21:01 pm »
CD4066 or CD4053 ? You would have to add a level shifter from TTL to the required control voltage for the CD4066 or 4053 when running it from about 15V. I think it can cope with 10V pkpk at 1MHz but I can’t be certain.
« Last Edit: September 06, 2024, 11:26:58 pm by G0HZU »
Re: RF switch
« Reply #3 on: September 08, 2024, 12:29:36 am »
I want the switching speed to be in microsecond. Relay switches are slower
Online ArdWar
  • Country: sc
Re: RF switch
« Reply #4 on: September 08, 2024, 03:12:17 am »
Switching 1MHz at microseconds is a bit redundant, no?
1MHz isn't that high of a frequency. Almost any CMOS analog switches can do that (and more). Maybe [A]DG419 if you only want SPDT and no need for T switches or unused input termination.
Offline Solder_Junkie
Re: RF switch
« Reply #5 on: September 08, 2024, 08:12:32 am »
I have used a 4066 to route RF in a home made transceiver where the frequencies involved were up to 20 MHz. The switching capability is +/-7.5V and switch times of a few nS.
Data sheet: https://www.ti.com/lit/ds/symlink/cd4066b.pdf
SJ
Offline Infraviolet
Re: RF switch
« Reply #6 on: September 08, 2024, 03:14:26 pm »
Doesn't the 4066 give quite a spike/dip (of a few tens to hundreds of nanoseconds length) on the passed-through signal whenever you switch it? So if you're only switching infrequently you're fine, but if you're switching very often you'll find these spikes replacing non-insigificant perods worth of the signal you're switching.
Offline geggi1
Re: RF switch
« Reply #7 on: Yesterday at 05:10:47 am »
look in to FET rf switches.
Online Zero999
  • 0999
Re: RF switch
« Reply #8 on: Yesterday at 07:17:10 am »
What's the load?
