Author Topic: Why is there a resistor across those bridge rectifiers ?  (Read 1453 times)
Offline tigrouTopic starter
« on: November 06, 2023, 09:32:52 pm »
I came across this schematic (power supply of a old Pinball). This is the secondary side of the main transformer :
What is not clear to me :
- Why do we have a resistor across some of bridge rectifiers ? Is it to protect them ? I would have say this to discharge some caps but that part is used to power the left and right flippers coils directly.
- Additonally one of there is (AFAIK) a variable resistor. Is it used for some kind of tuning (since it's not self regulated, unlike a SMPS)
« Last Edit: November 06, 2023, 10:07:48 pm by tigrou »
Offline Whales
    • Halestrom
Re: Why is there a resistor across those bridge rectifiers ?
« Reply #1 on: November 06, 2023, 09:44:25 pm »
Best I can think of is that maybe the diodes were getting fried by inductive kickback from the flipper coils?  Perhaps the few K resistance is much better than the many megaohms a backwards diode looks like.  But there are better ways of doing this.  No the diodes in their existing config will handle anything that arcs through the switch/contacts.
« Last Edit: November 06, 2023, 09:46:51 pm by Whales »
Offline Floopy
  • I'm going to need another oscilloscope to fix that
« Reply #2 on: November 06, 2023, 09:47:09 pm »
My guess would be to provide a very crude way of regulating voltage. The variable resistor can adjust your peak output. Someone is bound to correct me though, just taking a guess. Is it just a coil connected to it? Or is there some switching occurring in between. Is it an analogue switch? Relay? Transistor?
« Last Edit: November 06, 2023, 09:49:40 pm by Floopy »
Offline DavidAlfa
« Reply #3 on: November 06, 2023, 09:54:48 pm »
It's just a minimal load to keep the output at a safe level.
Transformers can reach way higher voltages than nominal in open circuit, a 12V secondary could easily output 18-24v.
The varistor provides further protection, as it's resistance decreases with voltage, thus increasing the load as the voltage rises.
« Last Edit: November 06, 2023, 09:58:06 pm by DavidAlfa »
The following users thanked this post: tooki, tigrou, Floopy
« Reply #4 on: November 06, 2023, 09:56:50 pm »
Here is the link to the full schematic (page 49). That file is available publicly that is why I included it here.
Online Doctorandus_P
« Reply #5 on: November 06, 2023, 09:57:44 pm »
Why are there red boxes on your schematic?
They obfuscate both the RefDes and the values of those resistors.  :palm:
Also, VR1 is not a resistor.
« Reply #6 on: November 06, 2023, 10:08:07 pm »
Sorry about that. I have uploaded a new picture.
Offline Veteran68
« Reply #7 on: November 06, 2023, 11:44:47 pm »
I was waiting for someone to call that out. I was about to. :)
