Often computer and electronic instruments were disturbed or damaged by welders and arc lamp ignition.
Jon
Short anecdote.
My late father in law used these ancient Asea DC generator arc welders (could be as old as from WW2 time, not sure).
They were built into the sixties at least. I've not had the opportunity to try one out, but they're said to be very, very good current generators (as alluded, it's a three-phase induction motor driving a DC generator) and a dream to weld with. The comparison at the time of course was simple AC-only welding transformers, not even DC. And welding (stick, of course stick, that's the True Form!) using DC is a whole different experience than fighting an AC transformer.
For starters, you've got the rotational inertia of the motor-generator set, so you can count on continued current delivery when resistance dips in the arc, and paradoxically, it becomes easier to weld using low current settings, because the welder will back that low current like nothing else; it will be what you set it to, and no fluctuation.
This is something they share with the better examples of the next generation heavy-duty welders, like the 20kW (3-phase 30A 400V) variants from ESAB and Kemppi. They're DC, courtesy of the then-invented high-power silicon diode rectifier, and they retain some of the niceties of the motor-welder. When you use one, again, you can go lower in current, because there's all this solid backing of power, and it feels like you can make your welding seam like a knife in butter, it's just effortless.
Compared to this, the PFC / SMPS ones are nowhere near as fun. But an ESAB or a Kemppi still will make that experience better than most.
