Author Topic: Half voltage shown by analog oscilloscope using CH1 and inverted CH2  (Read 981 times)
Offline j57H8I4Topic starter
Why when I use my probe with its own ground cable my analog oscilloscope shows the right voltage, instead when I use CH1 probe with inverted CH2 probe my analog oscilloscope shows half voltage value?
Offline danadak
Re: Half voltage shown by analog oscilloscope using CH1 and inverted CH2
« Reply #1 on: April 03, 2017, 02:29:46 am »
Both channels set to same V / cm ?
If you feed a square wave into both channels, one inverted, you will get 2X
resulting waveform. Both probes same attenuation, 1X or 10X.
Regards, Dana.
