Author Topic: What's this connector called?  (Read 2220 times)
Online SolderOcelotTopic starter
« on: November 13, 2018, 12:52:05 pm »
So what's this 3-pin connector called exactly? It's used often for laptop fans. The PC version often has 4 pins.
I think it might be called a crowtail connector, but there is a slight detail (inward bending hook) in aforementioned one that makes me doubt it.
I'll be needing one in a DIY project (laptop fan tester).
EDIT: yes, I've named the genders wrong in the photo..
« Last Edit: August 02, 2024, 11:20:18 am by SolderOcelot »
Offline Sudo_apt-get_install_yum
Re: What's this connector called?
« Reply #1 on: November 13, 2018, 12:56:23 pm »
I think it’s a Molex connector since the stationary fan connectors are Molex 2510 if I’m not mistaken.
Mind posting a picture?
The following users thanked this post: SolderOcelot
« Reply #2 on: November 13, 2018, 12:57:39 pm »
Lol I've been trying to post it for 5 minutes now. I gave up on the [img] tag and uploaded an attachment.
Offline Monkeh
« Reply #3 on: November 13, 2018, 01:10:18 pm »
Molex Picoblade, I believe.
« Reply #4 on: November 13, 2018, 01:14:02 pm »
I think you're right. Looks exactly right on Google images.
However I'm also getting similar results with JST connectors
« Last Edit: August 02, 2024, 11:20:27 am by SolderOcelot »
« Reply #5 on: November 13, 2018, 01:33:02 pm »
I've found this image which helps. I'm dealing with a Molex picoblade indeed.
Edit: They also call it JST 1.25mm (pitch)
« Last Edit: August 02, 2024, 11:20:34 am by SolderOcelot »
Offline Efe_114
  • Country: tr
« Reply #6 on: November 13, 2018, 05:39:41 pm »
Every connector is also called JST X mm i dont know why
Test gear: Aneng8009, 30V 5A chinese PSU( 1.5V peak-peak noise)
« Reply #7 on: November 13, 2018, 07:04:44 pm »
:-DD I've noticed
