Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
MC34063ECD-TR How to wire it for 3.3v?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: MC34063ECD-TR How to wire it for 3.3v? (Read 5062 times)
Bluestreak66
Regular Contributor
on:
June 16, 2013, 01:44:21 am »
I'm trying to build up a 3.3v power supply and would like to use a MC34063ECD-TR the input will be 24vac half wave rectified and I need 3.3v @ around 1 amp. I've looked at the data sheet and can't figure out how to size the components. The way I understand it is it uses a 1.25 volt internal reference and switches the output on if the feedback is below that and off if above? So I need to change resistor value accordingly correct? Also the inductor determines the efficiency and max output current correct? So how do i determine the value of that? Those are the two things I'm struggling with. I'll put a link to the datasheet. I know there are several swithing regulators like this one and the all look to be the same to set up. This one seems to be the lowest cost solution that fits what I'm needing. Any help is appreciated Thanks
http://www.st.com/web/en/resource/technical/document/datasheet/CD00001232.pdf
Logged
c4757p
Super Contributor
Country:
adieu
Re: MC34063ECD-TR How to wire it for 3.3v?
Reply #1 on:
June 16, 2013, 01:47:23 am »
Have you watched Dave's video on this? He did a pretty good video on the MC34063.
Logged
No longer active here - try the IRC channel if you just can't be without me
mariush
Super Contributor
Country:
Reply #2 on:
June 16, 2013, 01:50:00 am »
There's also an online calculator that's pretty good :
http://dics.voicecontrol.ro/tutorials/mc34063/
Logged
Bluestreak66
Regular Contributor
Reply #3 on:
June 16, 2013, 01:55:32 am »
Totally forgot about that ill give that another watch! mariush I've been looking for a calculator like that for the past hour you are awesome!
Logged
mariush
Super Contributor
Country:
Reply #4 on:
June 16, 2013, 02:02:42 am »
I guess your google-fu is horrible.
Google for "34063 calculator" or "mc34063 calculator" ...
MC34063A development aid
http://www.nomad.ee/micros/mc34063a/
MC34063 Universal Calculator (open source software on Sourceforge)
http://sourceforge.net/projects/mc34063uc/
MC34063 Calculator Online > Step-Down, Step-Up, Inverter
http://www.bobtech.ro/tutoriale/componente-electronice/43-calculator-online-mc34063a-mc34063-step-down-step-up-inverter
MC34063 parameters calculator
http://ukpyr.narod.ru/calc_mc34063.htm
etc
Anyway, glad I could be of help.
Logged
Bluestreak66
Regular Contributor
Reply #5 on:
June 16, 2013, 02:33:50 am »
lol ya I was using the whole part number my bad
I got all the numbers I needed. I'm laying out my board now. Thanks again!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
