Greetings,
I wanted to play around with the MC34063 in the boots configuration with external darlington, boosting from 3.5 volts, to 12 volts. And as long i dont apply anyload, it gives me 12 volts, although it does seem to have significant ripple.
if i load it with 10ma the output drops to 2 volts, this has me puzzled. But my thinking is this is a common part, so someone else might have had experience with the part in a simliar configuration.
I use the MJD122 as the external switch, i am however unsure about how to get the value of R3, 100Ohm is just choosen at random, i only found one datasheet where they had an example with the external darlington, something with its not allowed to get saturated.
I use a 3300uf cap on the output, this was the only one i had at hand that was had more capacitance than what was needed, i can see that it draws a lot of power for an instant during power up, but then it settles at 1 to 2 ma.
I get 56khz when looking at Ct, and the sawtooth looks very sharp
on pin 6 +7 i see 21 volts, looks fairly stable, pin 8 has some ripple between 16 and 21 volts.
and on the output with my scope i see 12 volts raising to 20. volts aswell, its all very odd:)
-lasse
