I've just spent the weekend frying some MC34063's and I think it's time I asked for help
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
What I'm trying to do is run a led strip from 4 D-Cell batteries. The LED strip draws about 35mA from a 9v battery and can operate up to 12v.
I was initially aiming for about 11v out and up to 200mA and using the downloadable calculator.
http://sourceforge.net/projects/mc34063uc/It worked briefly then burned out.
Then I thought that I would be more realistic and aimed for lower output current for the details aiming for 10v and 50mA.
I forgot to swap the output capacitor to a lower value and burned out the second chip. It worked initially but couldn't keep going and burned out after about 30 seconds
I lowered that cap to the right value and tried again and burned out another one after about 1 minute.
It was after that that I went looking at different calculators and Dave's video to try and get an idea of what I was doing wrong.
I get the impression that the internal darlington is what's burning out.
The calculator I was using had the Drive Collector resistor at very low values (50 Ohm and 100 Ohm) which I realised was unnecessary after I had watched Dave's video on it. I'm wondering if this was an issue.
I rolled my own inductor through a large bead using suitable current rated wire and i'm wondering if the build quality of the inductor could be so bad that it could cause my burn outs.
I'm worried about the behaviour of the IC as the battery supply voltage drops. Will it shut off nicely as the voltage drops below 3 volts or will it burn out the chip?
I'm surprised by the variations in the value of the Ipk sense resistor as I change values in the calculators. Am I better designing it for a higher current and a smaller sense resistor and only run it at low current or should I aim for lower output current and larger sense resistor using a design that's closer to my expected current usage?
Is a higher frequency safer than a lower frequency?
What areas of the circuit do I need to pay attention to ensure that the circuit is "robust"?
