Author Topic: maximum burden resistor across CT  (Read 2414 times)
Offline embedded.world@aol.comTopic starter
« on: July 04, 2014, 09:53:08 am »
How to calcluate maximum burden resistance across CT.
I have CT with 60Hz frequency.
I want to generate 2.5V across it to measure it across adc.
How to calculate what could be maximum & minmum values of burden resistor for proper operation i.e without saturating the core.
Offline rob77
  • Country: sk
Re: maximum burden resistor across CT
« Reply #1 on: July 04, 2014, 10:10:28 am »
sorry i don't have my crystal ball with me , therefore i can't guess the missing details accurately  to provide you a meaningful answer :D
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: July 04, 2014, 11:12:18 am »
Too large a resistance and the winding inductance reduces gain and causes phase shift.  The cutoff is: Rb <= 2*pi*F*Ls*/err, for err ~= 0.  Example: err = 0.01 (a 1% gain error).
This requires knowing the winding inductance, which is usually provided.  Sometimes, manufacturers will give a recommended maximum resistance, directly.
Seven Transistor Labs, LLC
