Author Topic: LED for TX and RX of MAX232N  (Read 5511 times)
Offline sean87Topic starter
  • EE WannaBee
    • EMBEDONIX
« on: November 29, 2012, 10:20:21 pm »
Hi all,
I have made a PC serial to CMOS level circuit (if this kind of circuit all called this!) using MAX232. It works fine, but I want to add 2 LEDs so I can see data going out or coming in to the chip. I want this to the CMOS level side of chip (T2IN and R2OUT pins).
Can I just hook up to LED's to this pins and ground? If not, what should I do? I looked in datasheet but didn't find anything on this regard.
EMBEDONIX - Embedded Systems, Linux and good stuff!
Offline digsys
    • DIGSYS
Re: LED for TX and RX of MAX232N
« Reply #1 on: November 29, 2012, 11:13:20 pm »
Assuming a 5V system, use 2K2-2K5 resistors (~2mA) and "good" leds. 50-100mcd (or high efficiency). Similar price to "cheap" leds.
That way you won't load the signals at all. I wouldn't try to run 20mA on a standard led.
OR IF you are not using the other 2 channels on the MAX232, link the 2 pairs together and use the 2nd pair just for leds.
  • EE WannaBee
    • EMBEDONIX
« Reply #2 on: November 29, 2012, 11:56:25 pm »
Thanks, got the idea.
Offline aluck
  • Country: ru
« Reply #3 on: November 30, 2012, 01:15:54 am »
Wouldn't it be better to put a small BJT to drive those LEDs?
Offline Smokey
  • Not An Expert
« Reply #4 on: November 30, 2012, 01:33:45 am »
Logic level FETs are great for this kind of stuff.  2N7002LT1 or something like that.
Offline hlavac
  • Country: cz
« Reply #5 on: November 30, 2012, 05:39:36 pm »
If you want a nice visible indication even for a single bit you could build two pulse stretchers
from single 74hct00 chip.
Look at the right side of my logic probe schematic to see what I mean...
Good enough is the enemy of the best.
  • EE WannaBee
    • EMBEDONIX
« Reply #6 on: December 04, 2012, 12:13:40 am »
Thanks for ideas!
I made the circuit. For TX/RX indicator LEDs I am facing a small or big problem! The CMOS level side of chip is always at 5v when idle. I connected a normal 5mm led to the GND and RX of cmos side and it is always on...when I send some data to chip, it slightly dims for a mili sec (I think it tries to show low bits !).
Any idea how to invert this process?
Offline kxenos
  • Country: gr
« Reply #7 on: December 04, 2012, 12:31:21 am »
Connect the cathode of the LED to the signal and it's anode to Vcc.
