Author Topic: Single Supply TL072 Op Amp -- Strange biasing  (Read 34135 times)
Offline poptones
Re: Single Supply TL072 Op Amp -- Strange biasing
« Reply #25 on: September 16, 2012, 04:31:37 pm »
Except I would never use a ceramic for bypassing or for anything else in an audio circuit. Use a good quality film.
If you increase the coupling capacitance you reduce the lf phase shift. Modern circuitry is so wide in  bandwidth it's easy to design for 10x the bandwidth - like -1db @ 1hz and 100khz.
