I will not go into 1x30000uF choice, because the dimension would be huge (although your 20A transformer would be huge too), and if it's goes wrong you will have to buy a new one, but if you use 4x7500uF, you'll get lower ESR,and if one goes wrong you are only replacing one of them not all, and although the overall volume will pretty much same, the placement of 4x7500uF is easier and better to see.
as for inrush current you can use NTC to reduce it, four of em, 2 on the ac output, and 2 on the rectified dc output.
everything will goes okay as long as you connect everything correctly,linear power supply is a pretty easy build.
