First I would like to thank everyone for helping me out in the last post (looking for a solution to eliminate the thick 20-wire cable). I decided to build a larger cabinet to house everything in one piece.
Now I am facing another problem. The original arcade machine uses 12V incandescent bulbs for lighting up buttons and coin mechs. The original bulbs breaks too often and doesn't look good (the buttons are yellow, the bulbs will make it look more amber than yellow), I ordered some LED lights and swapped them in - and I never expected such problems -
- I cannot turn off the LED lights (they dim a slight bit when I turn them off in the menu)
- Measuring with a multimeter it shows 12V when turned on and around 10V when it should be off.
I understand this is perfectly fine with incandescent bulbs as they doesn't fully light up until the rated voltage is reached, but LED lights have a larger threshold.
Is there anything I can do to make the LED light work? The 12V for the bulbs is output from an IO board which I cannot modify. I cannot just lower the input voltage as there are other crucial component on the board. There are 5 buttons, each have their 12V+ line and a common ground.
I have very limited knowledge about circuit building and the only thing I know should work is adding a relay but it is not exactly cheap and quite bulky for a little bulb. I still have 20 machines to go and I really want the LED to work.
