Does a MOSFET's Gate current vary with the load on the device across Drain and Source? If you `scope a Gate switching waveform, say in a SMPS, does the load affect the waveform? Thanks. Just curious as the driver IC for the Gates is advertised as being able to deliver up to 1.6 Amps, and I don't see why such high currents would occur. As an example here's my waveforms on two paralleled pairs of IRFP450 devices. There was no voltage / load on the output at the time. 136 kHz drive frequency. Will this vary when they are loaded?
