Author Topic: Low temperature solder  (Read 5468 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: December 19, 2014, 03:06:50 pm »
Hi guys,
Can I use normal solders ( Pb-free ) for temperatures around -50 deg. C? I've heard of tin pest, but I'm having problems with finding the specific values for which solder alloys are meant.
Thank you,
Offline Richard Crowley
  • KJ7YLK
Re: Low temperature solder
« Reply #1 on: December 19, 2014, 03:21:14 pm »
It is not clear that temperature has anything to do with the "tin whisker" problem.
Since when has lead-free solder been described as "normal"?
What is the context here?  Are you talking about a one-off hobby or custom project?
Or are you designing some mass-produced consumer product?
  • Country: sk
    • My site
« Reply #2 on: December 19, 2014, 03:33:34 pm »
Thank you for your reply. I was worried more about things like tin pest and solder brittleness rather than whiskers.
The context, well, a small series product that should be able to withstand (though not necessarily work during) low temperature storage and transportation.
Edit:
Since the EU went batcrapcrazy and effectively banned Pb based solders.
Also, I meant normal as in off the shelf, no specific marking, standard, etc.
« Last Edit: December 19, 2014, 03:35:35 pm by daqq »
  • KJ7YLK
« Reply #3 on: December 19, 2014, 03:42:05 pm »
Does the ban strictly apply to YOUR situation?  Are you mass-producing consumer products for general sale?
If you are worried about harsh environmental conditions, you could consider using a conformal coating over the PC boards after assembly.
« Reply #4 on: December 19, 2014, 05:43:27 pm »
He is worried that tin will change crystal structure at around -38C, and go from a lustrous smooth metal to a brittle crumbly paste. The only way is to use a tin free solder, either all lead, or lead alloys or one using Indium.
http://www.aws.org/bsmc/wj1009-43.pdf
http://www.indium.com/
  • KJ7YLK
« Reply #5 on: December 19, 2014, 06:19:19 pm »
So, in effect, the EU has banned the manufacture of any low-temperature electronic apparatus?
Will all the European countries be moving out of Antarctica?
It seems rather clear that making something that will survive -50°C requires something more than generic, off-the-shelf solder.
« Last Edit: December 19, 2014, 06:22:23 pm by Richard Crowley »
  • Country: sk
    • My site
« Reply #6 on: December 19, 2014, 07:22:54 pm »
Yup, that's what I was asking.
I'm having trouble finding a definite answer to whether I can use specific alloys at specific low temperatures.
It doesn't really seem that clear to me having never dealt with such a problem  :)
  • KJ7YLK
« Reply #7 on: December 19, 2014, 08:06:39 pm »
As SeanB said, it appears that Indium (and Bismuth) is your friend....
Here are the "low temperature" solders listed at Wikipedia
In97Ag3Wettability and low-temperature malleability of indium, strength improved by addition of silver. Particularly good for cryogenic applications. Used for packaging of photonic devices.
In90Ag10Nearly as wettable and low-temperature malleable as indium. Large plastic range. Can solder silver, fired glass and ceramics.
Bi100Used as a non-superconducting solder in low-temperature physics. Does not wet metals well, forms a mechanically weak joint.[35]
Bi58Sn42Bi58. Reasonable shear strength and fatigue properties. Combination with lead-tin solder may dramatically lower melting point and lead to joint failure.[28] Low-temperature eutectic solder with high strength.[17] Particularly strong, very brittle.[15] Used extensively in through-hole technology assemblies in IBM mainframe computers where low soldering temperature was required. Can be used as a coating of copper particles to facilitate their bonding under pressure/heat and creating a conductive metallurgical joint.[59] Sensitive to shear rate. Good for electronics. Used in thermoelectric applications. Good thermal fatigue performance.[66] Established history of use. Expands slightly on casting, then undergoes very low further shrinkage or expansion, unlike many other low-temperature alloys which continue changing dimensions for some hours after solidification.[35]
In52Sn48In52. Suitable for the cases where low-temperature soldering is needed. Can be used for glass sealing.[59] Sharp melting point. Good wettability of glass, quartz, and many ceramics. Good low-temperature malleability, can compensate for different thermal expansion coefficients of joined materials.
Bi49Pb18Sn12In21Cerrolow 136. Slightly expands on cooling, later shows slight shrinkage in couple hours afterwards. Used as a solder in low-temperature physics.[35]
Bi50Pb26.7Sn13.3Cd10Cerrobend. Used in low-temperature physics as a solder.[35]
Bi44.7Pb22.6In19.1Cd5.3Sn8.3Cerrolow 117. Used as a solder in low-temperature physics.[35]
Cd70Sn30Cd70, thermal-free solder. Produces low thermal EMF joints in copper, does not form parasitic thermocouples. Used in low-temperature physics.[35]
In100In99. Used for die attachment of some chips. More suitable for soldering gold, dissolution rate of gold is 17 times slower than in tin-based solders and up to 20% of gold can be tolerated without significant embrittlement. Good performance at cryogenic temperatures.[90] Wets many surfaces incl. quartz, glass, and many ceramics. Deforms indefinitely under load. Does not become brittle even at low temperatures. Used as a solder in low-temperature physics, will bond to aluminium. Can be used for soldering to thin metal films or glass with an ultrasonic soldering iron.[35]
Ref: http://en.wikipedia.org/wiki/Solder
  • KJ7YLK
« Reply #8 on: December 19, 2014, 08:08:55 pm »
Remember also that other components (besides solder joints) need to be specified for at least that extreme "storage temperature" even if not operating at that temperature.
I would be particularly careful about capacitors, and especially electrolytics, etc.
Offline Zero999
  • 0999
« Reply #9 on: December 19, 2014, 11:23:30 pm »
Lol, the legislation is only for consumer products. It doesn't apply to specialist applications such as military, aerospace and rough service.
