I wasn't sure whether to ask this here or on another part of the forum, but this feels like a beginner's issue so here it goes.
I have an alarm clock that I would like to modify so I can control it with a micro-controller. I eventually want to build my own alarm clock for this project, but don't have time at the moment to do that.
I want to be able to switch the alarm mode on and off using the uC. Below is a rough diagram of what I believe the switch does after cracking it open:
(I can't seem to figure out how to post an image so...)
Sliding Switch
______ ON
Vdd_________/
______ OFF
ON and OFF run under the 7-Segment Display to what I assume is a uC.
How can I replace this switch with a transistor setup?
I couldn't find common inside the clock, and most of the main pcb is covered by the 7-segment display which is held down with sonic welds I don't want to break.
Any thoughts on how to switch this would be greatly appreciated. I don't have any experience with mosfets but would like to use them more just to get acquainted with their use.
Thanks for any advice here.
