Thanks for the answers. The wiring will be outdoors, so it is basically has to be splash proof. No submersion will be performed. An usually such connectors do come already with wiring or rubber sealing on the cable entry point.
when you start putting in IP ratings in the catalog like farnell, you get the screw together ones, but I need to be able to quickly disconnect them quite often.
