Hi all,
If somebody here is using eagle, can you please explain the workflow when trying to get 3D PCB design along with fusion 360.
Their managed libraries system sucks really hard, so basically, I want to download my preffered libraries and use them locally, but I would also like to get my 3D PCB at the end.
As far as I've seen solution is to export components used in project to single library and then individually map those components to 3D packages. Problem is, If I use something from a huge library like rcl.lbr for example, the script extracts all those unwanted devices in to my exporeted library, which is silly really ,, and tedious to delete all those unnecessary devices every time.
SO maybe I am missing something, can someone please share their bulletproof method in making this simple.
Sadly I must say eagle is crap, and I would really never use it, but it is free, and comes with bunch of libraries, which is the only reason why I am giving it a shot.
Could also try kiCad, which i heard is significantly frendlier and better, but not sure if it's library count is as big as eagle's?
