Author Topic: Looking for a connector (see picture)  (Read 669 times)
Offline desperateTopic starter
« on: August 24, 2022, 08:53:40 am »
I'm looking to source a connector.  It is 9/16 wide, 3/16 tall, 4 pin.  Sort of looks like a PC board edge connector, it would grip both sides of the PC board.  Note the top right connector is missing a small piece of plastic that the other three have... but it should be there, it broke off. Doesn't affect the function (so far).
Note the top corners are beveled, otherwise it would be rectangular.
This particular one, and my primary use is for a power connector for a ResMed AirSense 11 CPAP machine.  Only the outer two pins are actually in use. But I think I've seen connectors like this in other situations, I can't remember where, though!
« Last Edit: August 24, 2022, 05:29:58 pm by desperate »
Offline Terry Bites
Re: Looking for a connector (see picture)
« Reply #1 on: August 24, 2022, 11:18:50 am »
Whats it from?
Offline Brumby
« Reply #2 on: August 24, 2022, 12:56:54 pm »
I feel I have seen that somewhere - but for the life of me, I just can't place it.
Offline pcprogrammer
« Reply #3 on: August 24, 2022, 01:00:09 pm »
At first I thought firewire, but that only has three pins per side.
Offline CaptDon
  • Country: is
« Reply #4 on: August 24, 2022, 01:33:45 pm »
Is that a shielded gigabit cable?
« Reply #5 on: August 24, 2022, 05:28:27 pm »
I'll add this to the posting... it's a power connector for a ResMed AirSense 11 CPAP machine.  Only the outer two pins are actually in use.
