Years ago they also made a big deal out of soldering heat reaching the transistor and damaging it. You were supposed to grab onto the lead with a pliers to stop the heat. Lead length allowed that to happen. Probably some truth to that way back when. Now we toast the crap out of them.
Exactly!
Germanium transistors were specially vulnerable.
I remember purchasing from Radio Shack a alligator-type heat sink that one would clip to the lead being soldered, to prevent heat from reaching the transistor.
In those days, as we were transitioning from vacuum tubes to transistors, we still used HUGE soldering irons. I had a gun-type iron. Weller. Put out humongous amounts of heat.
Another reason, in the pre-PCB days, the wiring was point to point. The photo posted by MK14 brought out some nostalgia.
