Author Topic: UV-C Light wand hacking / IC Identification  (Read 2108 times)
Offline ErwinTopic starter
« on: March 28, 2013, 12:48:49 am »
I could get a cheap UV-C Light wand (SG150 uv wand), and I thought that with some hacking I would be able to use it to erase EPROMs.
It has 2 leds. When you connect power the red light turns on, you have to press the button for 3 seconds and the green led will start to blink. Press the button again and the green led will burn continuously AND the UV light will turn on for 30 seconds.
This is not long enough, so I wanted to modify this device but it seems to contain some completely unmarked 8-pin IC. I did some measuring using my DMM and Scope.. and I think it's safe to say it's not a 555 timer or PICAXE. It uses a 0.9 MHz clock signal, contains some processing capabilities, and outputs  a 95.2 KHz signal for 30 seconds when activated. Which in turn gets turned into some really high voltage. My DMM has a maximum of 600 volts and it showed 1100 / 1300 volts for 1 second before going into protection.
If I know what IC this is, maybe I'm able to read it, modify the code and reprogram it to just output the 95.2 KHz signal whenever it has power, not even bothering about the pushbutton. Any ideas?
EDIT: The bright red line on the board is +6 volts, the yellow line on the right is GND. The three small transistors are S8050 NPN transistors. The three larger ones (near the HV transformer) are D882 - NPN medium power transistors.
« Last Edit: March 28, 2013, 12:56:34 am by Erwin »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: UV-C Light wand hacking / IC Identification
« Reply #1 on: March 28, 2013, 09:33:47 am »
PIC12 series, probably PIC12F508
Day Job: Mostly LEDs
Offline amyk
« Reply #2 on: March 28, 2013, 10:55:30 am »
I've always wondered how helpful a search engine for IC pinouts would be...
Beware the duty cycle of the power supply; it might not have been designed for continuous operation.
« Reply #3 on: March 28, 2013, 11:22:10 am »
Thanks Mike!  O0
Well.. I don't worry about the power supply, will connect it to my lab supply. Let's remove that chip and read it to see what I can do with it  >:D.
« Reply #4 on: March 28, 2013, 09:13:39 pm »
Ok, after several hours of trying, i'm not able to read this PIC12(?). I think it's either not a PIC, or it's protected.
Anyway, currently looking for an other way to power the 4 watt UV-C tube, any suggestions (using components on the board?)
