@f5r5e5d
Care to elaborate on the first sentence further? S-beams are available, it could be good solution. Regarding the ADCs, I could run into some problems with interfacing the ADCs and PLCs, a instrumental amp circuit should do the trick.
@woodchips
Maximally balanced as in container would be symmetrical and reverse cone shaped and material in it would be pretty much evenly spread. Brainfart moment, yeah, definitely sum of the load cells.
For the accuracy, I haven't yet spoke in much detail with the man who requested this system, but +-0.5kg or even 1kg should be fine.
@PA0PBZ
It's a potentially not an one off, but a prototype. A local owner of a workshop for farming machines and accessories is looking to make a automatic system for measuring and bagging of grainy materials like cattle food, grain, wheat and so on. I'm still a student, and this would be a nice opportunity for getting some hands on experience, and I get to play with some relatively expensive gear. The owner of the workshop is fully aware of this, and I'm grateful, so I'm looking to do a good job here, and not mess something up.
Regarding the overload shock, there should not be any, the bags will typically be 50kg, and the material would be transported via screw conveyor which won't overload the container.
